| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | That light gauge L-shaped piece of metal pulls out to release the hose. It has a groove in it that holds the hose fitting in place. There are no threads if you're trying to turn the hose fitting to unscrew it. Grab the L-shaped metal with a pair of pliers and pull. A screwdriver prying between the hose fitting and L will help get it started.
