| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | With correct oil clearances and an accurate pressure gauge, 15 at idle and 30+ at cruise RPM is excellent. Back when those engines were new, most people used 30 weight in the summer, and switched to 20W-20 in the winter. I'd definitely recommend HD 30 (detergent) oil instead of non-detergent. The non-detergent oils available today are way down in quality, mostly intended for getting a few more miles from worn-out engines that burn or leak so much oil that oil changes aren't necessary. "Fill it up with oil and check the gas!"
If you want to use a multi-grade oil for some reason, 15W-40 Diesel rated oil would be a good choice. Jerry
