| | | Forums66 Topics128,026 Posts1,055,410 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | On my 58 half ton with a 235 the shop manual calls for a special lock washer for the rear engine mounts that bolt thru the bell housing. One of mine on the passenger side was missing. I thought the bell housing bolt holes were threaded so I thought I threaded the bolts thru. Some how one fell out. When I removed the engine and installed the new engine I do not remember there being locks and nuts on the top side of the bell housing legs. Anyone know what lock washers they are referring to in the shop manual. | | |
