pulling the bellhousing off my 235, i have discovered the p.o. has covered a factory hole in the rear of the engine, under the bellhousing, with a piece of sheet metal and some gasket sealer. what goes in this hole? seems to need some kind of freeze plug, although it is not in the water jacket area. does anyone have a part #.?
