| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Disconnect the wires at the back of the ammeter, being sure to label which wires go to which post. (Take a picture if possible) The meter needle should go to center. If not, you have troubles inside the meter. Repair or replace it. If it does center, reconnect the wire from the starter connection battery cable. Again, the meter should stay centered. If it's wired right, that should be the only wire attached to that post of the ammeter. Reconnect the other wires one at a time. If one is shorted, or has a high-resistance voltage leak, the meter will deflect when the leaky wire is connected.
I'm going to guess you have an internal problem in the ammeter. Jerry
