| | | Forums66 Topics128,190 Posts1,057,342 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Do you have the foot stomp starter switch ? If so, it may not be the starter but the starter switch. This starter switch sits on top of the starter and is held on by two 3/16 screws. Remove the switch and turn it over to see if the copper parts of the switch are corroded. If so, clean them up. Another item to check is the solid copper plug that sits atop the starter underneath the switch. make sure that is clean and not badly worn. Just my 2 cents.....
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
