| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Keep in mind, there are 2 different blends of Sta-Bil. You need to use the Sta-Bil for ethanol gas if that's what you're treating. The old 'regular' Sta-Bil doesn't work with ethanol. Which old 'regular' Sta-Bil doesn't work with ethanol? " DOES THE ORIGINAL STA-BIL® FUEL STABILIZER NO LONGER WORK WITH ETHANOL FUELS?
This is absolutely NOT true. STA-BIL® Fuel Stabilizer is effective in storing gasoline for up to 12 months in ALL Ethanol blended fuels, up to E-85. It prevents gum and varnish formation/build-up caused by the breakdown of fuel and also helps prevent corrosion from moisture/humidity during storage. " http://www.goldeagle.com/brands/sta-bil-faqs | | |
