| | | Forums66 Topics128,054 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are two styles of "Main Well Housings" and gaskets. If the wrong gasket is used it will tip the housing so the power valve piston will not hit the power valve ball in the center.
See the USA in your vintage Chevrolet! My Blog | | |
