A new lifter needs a little running time to pump up with oil. It is hard to adjust it with a new lifter as there is little resistance after you take up the slack. Back it off & turn the adj. down till there is no play in the rocker. Then turn it down the additional 3/4 turn.
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
