2 members (55shaker, Paul_WNC),
75
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Could it be the valves? According to the owners manual the valves should be adjusted with every tune up. I just adjusted the valves on my 235. Very easy procedure. 8 of the 12 valves were right were they should be. Four of them needed adjusted. this eliminated the rattle/knock I had at start up and acceleration. Here is a good procedure for adjusting them. This was my first time and I did it in about 30 minutes. http://devestechnet.com/Home/ValveAdjust
