| | | Forums66 Topics128,180 Posts1,057,148 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I've had a couple of different suspensions. The first one was from a 79 C10 that that I narrowed and bolted onto the frame. I used a set of dropped spindles and cut a coil and a half to bring the nose down. I went this route because it was relatively inexpensive, got the ifs for free, cost me $60"to narrow the crossmember & center link. I drove it for a couple of years but decided I wanted to lower it a bit more & run larger tires so I opted for the bolt on mustang ii. Just finished the swap last week. Love the stance & the ride is even better.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
