| | | Forums66 Topics128,284 Posts1,058,532 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1,135 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,135 | The toe board on Sparky needs some repair and parts replacement,
1) The gas pedal rubber covering is shot and needs replaced or the whole pedal replaced. How is the pin holding the pedal onto the board removed? I tried punching it out without any joy. The pin holding the pedal has a small hole on one end, as if for a cotter key??
2) There is a small hole on the angled bracket holding the pedal onto the back of the pedal. Is there some other part, missing? If so what?
Any info help will be appreciated. | | |
