7 members (Bill Trotter, Southerntruck, Hotrod Lincoln, JoergK., Cosmo, klhansen, Stovebolt48),
116
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,373 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy jetmech6868, the short answer is yes, but the one ton may be an open driveline type while the half ton will be a closed driveline type. Parts can be swapped between the two transmissions to configure it to what you require, if both transmissions are closed driveline type then they might be a direct swap. The only issue then might be the universal joint size but you should be able to swap output yokes, hope that helps. | | |
