| | | Forums66 Topics128,131 Posts1,056,726 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Those heads may not have the bolt holes in the front to mount the alternator, a/c . But they will boost the compression a little bit, a quadrajet will help a little also. Might want to go with hei dist while you have the distributor out .
Tommy 59 apache 1/2t 261 short stepside | | |
