What original year/application engine?
Have you adjusted the valves?
Have you tuned the engine: points, plugs, timing, carburetor.
Were adjustments/tuning done per Shop/Owner's Manual - what year manual?
Who told you to do a rebuild?
What is your oil pressure at idle (400-500 RPM)?
What is your oil pressure at 1,000+ RPM?
