| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,828 | A year-correct 55 265 will not have the canister type oil filter at the rear corner of the oil pan. It uses the same bypass filter as the 6 cylinder engine. 55 was the only year that filter system was in use on the V8. In 56 they went to the full flow filter integral with the engine block. Jerry
