I'm finishing bodywork on my doors and just put them on to align the hinges. My problem is, the doors don't fit very well. It doesn't have to be perfect, but both doors sag low on the latch side. It drops down about 1/4" on the bottom. Could this be because the cab isn't bolted to the frame, and the cab is actually high in the back (which would fix the door problems once bolted down)?
