9 members (frogfarmer, J Lucas, Gdads51, carbking, Charles in CA, Wally / Montana, Nick in Manitou, sron48, 1 invisible),
88
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Man....I got it open...used a bell hangers twist drill. Turned it by hand and drilled out black fine sand. Then I used the wire coat hanger end that's twisted like a cork screw pushed that in and out a bunch of times. My wife's idea was a small baby bottle brush worked also. I pressurized the system with water ...nothing....back to the drill bit and wire coat hanger. The wire went in 6 inches and that did it. Pressurized the system again and at first lots of air then goo then clear water . Next step will be to use Bars Leak Flush with the block plug reinstalled then drain the block. I hope I got it all out if there is something I missed or can do better please let me known....thanks
