They are 3/8" coarse.
I would not worry about having them though.
I need to remove the studs on some of the jobs I do as 235 manifolds tend to warp up at the ends. If the intake alignment rings are used the end pins can prevent the manifold from going on.
It is much more important to use the intake rings.
My Blog
