Cut the green foam away on the inside of the filter, then the least resistance should be through the filter, up and over the center portion, and down to the carb. Some thin rubber or card stock would direct the air through the filter if laid over the foam before the paper element is installed. But, even with all that, the foam will do a good job of filtering.
I have two of these cleaned and ready to convert. Just haven't had the time yet or found the right filter. I know have a starting place.
Joe
That's more or less what I was envisioning. Just needed some confirmation on my logic.
Paper filter is going to be kind of a glorified spacer if the air isn't forced through it.
Still a really cool concept. As Denny mentions...much less monkey business than other attempts I've seen.
