Dan,
In the tech tip's, there is a very well written article to answer your question. Also, Grigg is actually documenting his project on his 1-ton in the project journals, and walk's you through it. A must read. I have done the pinion upgrade on my 1-ton as well, and it's a wonderful thing. Easy also. The hardest part is finding the donor carrier section. Good luck!
