| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,796 | If it makes you feel better, go ahead and trim the shims so the ropes can touch, but I've never noticed a problem with a thin piece of shim stock between the upper and lower seals. It's much more likely that the bearings have worn enough to let the crankshaft bounce around on the seal and make it leak. Be sure to check and adjust the oil clearance while you've got the main cap off. Jerry
