2 members (TUTS 59, 1 invisible),
192
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | With the floor cover off the distance from toe board to transmission will be close to the 3 speed distance. If I remember correctly(an issue for sure) the powerglide transition is smaller than the bell housing. That part that covers the torque converter. The issues will come from the torque tube rear end, I think. The issue that might concern me would be the Mating of the drive shaft to the transmission. If you have an "open" driveshaft then it will be easier.
Steve H
