| | | Forums66 Topics128,283 Posts1,058,515 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | What Mother said is probably the best advice. My Chevy Duty Replacement blocks are. 1+13/16" high x 2" wide x 2+1/4" Length. The length part rests on the top of the frame, then drill hole down the center of the top. The overall height with thin rubber cushions on either side of the block is 2+1/16". You would not want the blocks any shorter than 1+3/4" high because you will have problems getting on the running board splash aprons. Good luck with your project.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
