You can't recenter the balancer without all screws being very loose. This means dropping the oil pan anyway because of the two bolts holding it in place from the inside. Once you have everything loose, its best to use the existing balancer to center it because it has a speedy sleeve on it. Good time to check the oiler spout.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
