| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Matt, If you choose to go the full-flow route, you would have to do some modification to the block. http://www.stovebolt.com/techtips/full_pressure.htmThe by-pass filter system works fine. Jim Carter sells a by-pass filter "head" that uses a spin-on filter. If you want an original-style by-pass filter, post a want-ad in the Swap Meet (or, ask Jim Carter if they have a used one - you might as well ask if the have a 1954-style used one). http://www.stovebolt.com/techtips/engines/oil%20filters/index.html | | |
