| | | Forums66 Topics128,164 Posts1,056,967 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Study your accelerator bell crank on the pin on the side of the block. You will see that by changing the position of the arm that has the rod to the carb that arm can become a puller instead of a pusher. A short cable can then be used to the carb throttle lever. The end of the cable at the bell crank has to be clamped so just the cable and not the housing moves. A lot of work when a Lokar set up can be installed in 30 minutes. For just the "pedal look" you could grind the rubber socket off the bottom of the factory pedal and let the Lokar pedal arm slide on the underside of the factory pedal. With the spoon removed and and painted flat black most wouldn't notice.
Evan
