8 members (greenie-reddy, G508, Guitplayer, klhansen, Peggy M, dt235sd, Otto Skorzeny, DennisM),
100
6
Mod | | | Forums66 Topics128,271 Posts1,058,412 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Steve,
Here a few recommendations:
I had that happen a few times (scarey) and cured the problem after a few "adjustments":
1. Removed grease/oil from the pedal-rod that goes the the floor/felt "seal" 2. Replaced the floor/felt seal (no grease/oil in/on that seal) 3. "Sharpened"/gently-filed the edges of the piece of metal that "catches" against the pedal-rod
I do not know which worked, but mine only releases now when I pull the release lever.
Maybe other people have remedies for this disconcerting/dangerous behavior?
