The sender/flange is grounded by the mounting screws. Since there is a gasket there and the straps can have pads and the filler has a rubber hose and paint and undercoating....(all insulators), it's a good idea to reinforce the ground with a wire from a sender flange screw to the cab or chassis. Grounding of the sender and/or gauge is the no.1 cause of "gauge not working". Of course the ground path back to the battery has to be good also. Do not ground the center terminal.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
