8 members (55shaker, 78buckshot, dt235sd, baldeagle, rick46ia, Stovebolt48, Gdads51, 1 invisible),
163
Mod | | | Forums66 Topics128,268 Posts1,058,379 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 55 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 55 | the easiest cheapest way. is to do a crossmember swap and put the entire front suspension from a 73 & newer truck under it. its almost a bolt in. and you can also bolt the later rear end to the GMC rear leaf springs. you will then have 5 lug wheels and a greater selection of rear gear ratios. | | |
