If you look closely at the pic you can see the clutch head srews that hold the pannel on.Ihave had the pannels off on my 51 to replace the windows.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are... My progress pics
