| | | Forums66 Topics128,276 Posts1,058,440 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | As long as the fuse is sized to protect the smallest gauge wire used in the entire circuit you will be fine. How small are the wires on the turn signal unit? 18 Gauge wire = 5 amp 16 Gauge wire = 10 amp 14 Gauge wire = 15 amp 12 Gauge wire = 20 anp 10 gauge wire = 30 amp Hope this helps, Mike B  | | |
