| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Very good chance the original Rochester 'B' was replaced with one from a 235. This in combination with today's gas formulation could be the source of your problem. This was a common replacement because they bolt right on and look the same It should be a 7005140 stamped 5140 on the lip of the throttle body flange.
dg
Denny G Sandwich, IL
