1 members (Naturalthud),
110
3
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Just FYI, the tooth count on the starter(6 Volt and 12 Volt stomp starters) is the same. The tooth count on the flywheel is different. The tooth pitch(size) is what is different on the 6 Volt starter from the 12 Volt starter. The Shaft diameter is different as well. The Solenoid is different 6 Volt verses 12 Volt, for the starters used with the push button or key switch.
Steve H
Entire Thread
235 not starting, burning out starters
| qdub | 10/20/2015 10:17 PM |
Re: 235 not starting, burning out starters
| JiMerit Boltr#43 | 10/20/2015 10:22 PM |
| gusco | 10/21/2015 12:45 AM |
| qdub | 10/21/2015 12:50 AM |
| truckernix | 10/21/2015 1:04 AM |
| Deve | 10/21/2015 1:41 AM |
| qdub | 10/21/2015 4:31 AM |
| qdub | 10/21/2015 4:34 AM |
| Dusty53 | 10/21/2015 2:12 PM |
| Deve | 10/21/2015 9:24 PM |
| dougs | 10/29/2015 4:10 PM |
| qdub | 10/26/2015 4:47 AM |
| Dusty53 | 10/29/2015 2:49 AM |
| Steve_H | 10/29/2015 5:54 PM | |
