| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Is that code an engine serial number or a vehicle serial number?
What is the size of the engine and what is the engine serial number (pressed into a 6 cylinder block rearward of the distributor)?
My guess is that it is a vehicle serial number (for a 350, 2-ton series truck, 137" wheel base).
Below are wild guesses of what each character/digit might signify (but, I do not know the order of the digits for 1959)
353 P S 2452 E
353 = 350 series 2 ton 353 - the "3" = 137" wheel base P = Pontiac, MI plant (a guess) S = 1958/1959 (a guess) = S-series (GMC did not ID engines by calendar year, they used a model year letter/code) 2452 = serial/sequence number = (I think) 1452nd 2-ton truck in that 58/59 series
Where did you find the code? - on title/registration - on VID plate
If it is on a plate, can you post a link to a photo of the code/plate?
There are members here and at the oldGMCtrucks discussion board who are more knowledgeable about GMC codes than I am. | | |
