Hi Walt,
As the boys are telling you, the 235/sm420 combo is at its performance limits with a Big Bolt in its stock configuration -- if you start modifying it, you make the truck pretty much undriveable.
Bottom line -- for safer, higher speeds, you need to switch out the driveline completely. It's a lot of work whether you just switch out engines and axles, or if you switch the body over to a modern chassis.driveline.
Grigg (moderator for this forum) is in the midst of doing that to a 2-ton and you can see his project here
Whichever way you go, there's a lot of expertise available to you here. Stay in touch with us and post some pictures somewhere (like photobucket) so we can see.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
