Engineering is going on for new brakes on the 1947 first series GMC EC-302 dump truck. Can someone tell me what the bore and stroke length of a stock master cylinder would be? Also, does the stock brake system, on these trucks, have a metering device to prioritize more pressure/flow from the master cylinder to the rear brakes? Or is the pressure equalized between the front brakes and the rear brakes?
Al
