9 members (Otto Skorzeny, Cosmo, RAC1812, cmayna, GRNHydra, HandyAndy, Peggy M, 1955 1 Series, 1 invisible),
144
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,982 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | With a full tank, remove the line to the pump. Gas should flow and make a mess. No flow? plugged. Gravity works well at this place. See post above to clear small stuff. If no joy, then pull line at the bottom of the tank. Careful, it will drain on you if not plugged. No flow? Plugged?. Push a stiff wire up into the tank to move the crud. Good times.
Steve H
