9 members (Southerntruck, Tyler Watts, Hush, JW51, Hotrod Lincoln, jasrking, Joe H, Gray_Ghost, Forty9),
107
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | TRUCKBIZ, you should state what truck it's going in. If it's going in a '55.2-59 you don't need to change side covers. If it's going in a '47-55.1 you do. '55.2 with 6 cylinder and the standard/overdrive is different from the 6 w/hd 3 speed and V8. It's more like the '47-'55.1, with the bellcrank in the linkage.
Bill Burmeister | | |
