| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | The only time the resistor will show a voltage drop is with the points closed and the ignition on. If the points are open, you'll see 12V on both ends of the resistor. With the engine running you'll see battery voltage at the upstream end of the ballast resistor and 9-10 volts at the coil + terminal, if everything is wired correctly. Jerry
