Great post Tim!
I especially like step #8. A lot of people (me included) often forget to do that.
If your idle was on the high side after you reach maximum vacuum, the mechanical advance in the distributor could have begun to kick in, monkeying up the process. This could be the case for both mixture, and timing adjustments.
Carl
