It will make you feel better doing it yourself too. Reason being, someday your fuel pump may go south. When it does, the replacement might have the in/outlets in a different position. When it does, you will need to re-bend your line. The auto parts stores have the lines that bend really easy. As long as you stick with the easy bend lines, a cheap flaring tool is all you need for the ends as well. Be careful though, next thing you know you will want to do brake lines, fuel lines, vac advance lines, pcv lines, your wifes car, etc etc. smile
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
