| | | Forums66 Topics128,086 Posts1,056,099 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | AK52, an idea to keep in mind. The Dealer put the turn signals on as an option. Some used the parts book and some used other suppliers. So, the idea of "stock" will have to be expanded for this item. The process, involves a "switch" That is the signal Stat. It is available in 2 versions. Integrated and, non-integrated. Integrated, will combine the Brake lights into the turn signal function(just like a modern truck), non-integrated, will keep those functions(brake lights, and turn signal) separate. So for you to decide. Now the parts you will need, and how to do it will depend on how you wan't the truck to look. This is a very good "Tech Tip" check it out: http://www.stovebolt.com/techtips/turn_signal.htm
Steve H
