| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Yep, Utility knife and a sharp blade. Slide in under the rubber, over the glass. Save the paint. It will expose the glass(and the dirt) for easy removal. It also gets the narrow cross section of the rubber. Less cutting that way. Some tape on the handle so the glass is not scratched. That is about it. When the rubber is cut this way the glass comes out easy so be careful.
Steve H
