| | | Forums66 Topics128,089 Posts1,055,991 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Taking it apart for a good cleaning and lubrication is easy and the nylon pivot ball can be easily removed. Then heating and bending is worry free. I made a DIY thread showing the basics of taking one apart when I recently customized mine. To disassemble, clean and reassemble, all you need is a grinder and a welder. You'll want to add some grease after you clean the parts. See my shifter thread LINK HERE.
