I hate to break this news to you but on your other THREAD ,
1954 3100 torque tube? How to reinstall shaft into torque tube?
You were having trouble with the front pinion bearing locking sleeve. I see you have that figured out.
Here is the bad news:
If you are installing a new Okie bushing sleeve assembly look at this,
PHOTO ALBUM
Note: There are 2 pages to the PHOTO ALBUM.
Since you have the Torque tube out of the truck.
Before you reinstall the pinion and attached propeller shaft into the Torque tube housing.
It would be easier to remove the propeller shaft oil seal, rear bushing and u-joint rear yoke bushing.
Just find a long pipe that fits inside the Torque tube, then from the pinion end of the Torque tube,
slide the long pipe down the inside of the Torque tube housing and drive out the propeller shaft oil seal,
Once the pipe makes contact with the oil seal, start driving it out, the oil seal will push out the
rear bushing and the u-joint rear yoke bushing along with it.
The thing is someone might have installed a Okie bushing sleeve assembly at onetime.
So you will have to drive that out first before installing the new Okie bushing sleeve assembly.
You could have the original front, rear bushings and oil seal.
What ever is in the torque tube, that long pipe will be able to drive it out.
The photo album shows the original rear propeller shaft bushing & oil seal is still in place. Photo
That is because that's all that needed to be fixed.
You leave in the old rear bushing & oil seal and slide in the Okie bushing sleeve assembly.
Since you have the propeller shaft out of the torque tube it is better to remove the rear bushing & oil seal it will run cooler.
Also the Okie's rear bushing and oil seal will have a new spot on the propeller shaft to ride on.
Okie Bushing History
The Okie bushing was created by the long gone National Machine Works Inc in Oklahoma, hence the name Okie.
It shortened the time and effort to repair the torque tube bushings and oil seal.
If you did it the way GM did it, you would remove the entire torque tube from the rear axle housing.
Remove ring & pinion gears
Pull out the propeller shaft from the torque tube.
Use special tools to remove and replace the bushings and oil seal.
Then reassemble everything. Pain in the Butt.
With the Okie bushing you just pull out the front bushing.
Then from the front of the torque tube you push in the Okie bushing sleeve, which has the Front bushing,
Rear bushing & Oil seal inside the sleeve.
You leave in the old rear bushing & oil seal.
Less Work.
Chevs Of The 40s 3.55:1 Ring-And-Pinion Swap Scroll down for photo album.
Okie installation
