1 members (Ponchogl),
108
2
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I haven't seen instructions, but the lower bearing to fit is available from some of the usual restoration suppliers.
Pretty much just remove the wheel, measure how much the stem sticks out so you can replicate that measurement. Then cut off the column from the box but extra long. Then figure out how long you want it and trim the tube to length. Install bearing and slip the center shaft back in as previously measured. Now depending on which telescopic shaft you use adjust length and machine the end to suit.
Still need to make a bracket to clamp on bottom of column and bolt to the floor. | | |
