| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | cassie,
I think you have asked the correct question: "Should the accessories terminal be hot when the engine is running?"
This is not clear: "The key is in the same position either way."
Nonetheless, switches behave differently, and you will have to check yours out.
Do you have a volt-meter and/or continuity tester? Check the leads on the switch with the switch/key in various positions. | | |
