Is it possible to put one of the smaller engine-stands on each end . . If it can be done, do like 4onthefloor says and mount it to the side.Just make sure the capacity of the stand is capable of holding the engine weight.
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us. - - Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
