| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Hello and welcome to the forum. Many trucks on here, mine included, are enjoying the T5 transmission. My signature can take you to my web pages about the T5. It is not a good choice for any hot rodding but will be just fine for a daily driver. Several gearing options exist and the best one will depend on what rear diff gear you have.
Another option is the 3 speed with a solenoid overdrive (can't remember the name).
The trickiest part of the T5 is keeping the cable speedometer working. If that isn't an issue, then the T5 swap is easy. It can be made to bolt right to your bell without an adapter plate, use your current clutch package, shorten your drive shaft, cut a hole in the floor for the shifter and it's pretty much done. Here's a LINK to the T5 installation I did on my 1965 C10. | | |
